That sounds like I will be free to go ahead and make a purchase. 'Output level fixed' sounds good. I would prefer it if bit-perfect was not interfered with by any controls, even volume.
It's a fair point you saying whether or not bit-perfect is from the outputs. Since it's not mentioned in the manuals it's a leap of faith, assuming it is bit-perfect.
However I was googling about max sampliing frequency from the optical output. There was no pecific result for it, but there were bluesound thread results. In two threads I saw someone from Bluesound refer to output being bit-perfect.
It makes me suspicious though when the manual doesn't mention stuff, but devlopers mention stuff in threads.
Anyway, my situation is that I have pondered for months/years over a file transport. I am not going to use Node as a streamer. I will most likely use it for music files via attached SSD drive. Plus internet radio sometimes. I realise this is in a way a waste of the Node's functions. However I am literally exhausted looking for a suitable transport. Like I looked for fanless laptops, but never find the one I want and give up. Plus I think a laptop would not be right for how I mean to use the transport.
RE: Artists, Albums, Songs, Genres, Playlists, Composers, Folders. Your post tells me that the Bluesound should see the files correctly, from an external SSD. I suppose I can try a Node and see what happens, but I wanted to be sure first, to avoid returns. Many, many thanks.
@gimmeheadroom
I found these threads on it yesterday when I checking to see if Node would be OK for me.
https://support1.bluesound.com/hc/e...285321-External-dac-doesn-t-recognize-24-192-
This one quotes from a Bluesound rep, in the third post by someone called Roger.
https://support1.bluesound.com/hc/e...multichannel-audio-via-Digital-Output-to-AVR-
Second post in this thread.
