Luke Thomas
I went to Node web site. Did not see any info about the new node. What’s is it called ? What is different from the Node 2i ? Thanks
It's now called the "Bluesound Node"I went to Node web site. Did not see any info about the new node. What’s is it called ? What is different from the Node 2i ? Thanks
Yes me also. I will someday. Get a long cable and try option 2. Thanks.Wired connection is just too difficult for me.
I also do the same but use Linksys Vekop nodes. All my equipment plugs directly into those. Minimizes the number of wifi devices on the network. My TV, receiver, and Node 2i are all connected to a Ethernet switch which is connected to a Velop node.I've tested my Node 2i wired* and wireless and I didn't notice any changes in sound quality but the wireless dropped out occasionally, so wired is more/100% reliable, and it responds to volume changes more quickly.
* the 'wired' version in this case was just plugging the Node into a TP-Link Deco disc (mesh setup). The Deco discs are ace. All my Bluesound equipment (one Node 2i and two Flex 2is) plugs directly into a disc.
