FastAndClean
Previously known as presata
i sold one of my pairs
now i have 3 pairs not 4
Guys... Should I buy a new BL-03 or is there something better in the budget section? Since mine has defective channel balance.
They didn't come defective. They became defective after some time. I contacted them.You already had a pair, and they were defective?
Did you like the sound signature? What about the fit? Good?
If yes on both, it’s gonna be hard to beat for the price. I’d get them again.
The other question I have is if yours were defective, did you contact the seller and arrange for a replacement pair?
It has happened while I was listening to music, all at once.Hey, is that channel imbalance was already there out of the box, or has it happened out of the blue?
It has happened while I was listening to music.
Thug life... Don't panic, everything's gonna be alright at the endi sold one of my pairs
4 pairs was a bit over the top, too much excitementThug life... Don't panic, everything's gonna be alright at the end
I tried listening without a filter and it didn't help. Definitely defective.I made a heads-up post some months ago about that: https://www.head-fi.org/threads/chinese-asian-brand-iem-info-thread.820747/page-1798#post-15218202. I think your filter nozzle just got clogged with ear moisture condensation and then you perceive one side getting quieter. You can take the filter off with a needle (gently pry the edge) and try to clean it using an alcohol swab or something similar and wait few minutes till it dries out. Usually, it fixes this issue without any problem.
Then I'll just get another one. Would be cheaper.I'm really sorry to hear that. :/
In my experience with a faulty Kanas Pro, the banned seller will ask you a video to prove the channel imbalance, then you'll need to send it back and wait for 1-2 months (shipping, time for the replacement), it's really annoying dealing with a defective unit. Good luck!
Luckily I have tons of IEMs like KZ ZSX or TinHiFi T2 with **** **** and AudioSense T800 incoming. But I'll buy Blons cause I enjoy their timbre, just not from the banned seller.I'm really sorry to hear that. :/
Your mommy shoulda punished you for that. Seriously.i sold one of my pairs
