Bitperfect almost perfectly working...Make sure to grab 1.0.5.
Tryed every variation on these
Equipment: MacBookPro->Schiit Modi->Schiit Lyr->Fostex t50rp "Maddogs"
Equipment: MacMini->NI Audio 2 DJ, Schiit Lyr->Sennheiser HD25-1 ii
Equipment: MacMini->Line 6 Toneport UX->Schiit Lyr->"Maddogs"
So after much twidling and persistence, a couple of hardware changes and I am still working great. I can summarize a couple of tips and findings
1. Basics
Scanning, make sure to do a couple of things first. I found this particular recipe worked.
Start iTunes:
Play a Song (I think this loads some type of internal list)
Open Bitperfect (Let is Scan for iTunes music)
Warning it might crash after the scan completes but you will see progress.
If this happens, start Bitperfect again and do NOT scan.
Play another song in iTunes with Bitperfect in Menubar
In Bitperfect preferences select the iTunes Music folder.
Special note once you have Bitperfect going make sure IF you have other
music that is outside of iTunes..
From Menubar->BitPerfect->Change Music Directory
and point it at whatever directory contains music inside the iTunes database but not in the
iTunes Music folder. (Got that?)
2. Sound
The settings I am using worked stability for
NI Audio2DJ and Schiit Modi.
3. Itunes
I found that the blips between sounds from list loading generally went away with this combo
4. Advanced
I also believe these had some effect on performance and quality
Hope this helps somebody or maybe I am stupid that it took a while
to work good. If anyone has any suggestions to improve this setup....
I do however really like an Audio Hijack setup for the Audio Unit plugin chain
advanced EQs, Spectrograms and whatnot.
Bitperfect is great though.
