The sound should be pretty much identical, this is how BitPerfect's reference system is set up. Gigabit wired connection to a Synology NAS, and we notice no degradation vs. the built-in drive on a Mac Mini.
Thanks, just what I needed to hear Agentsim.
I recently picked up some vintage receivers which are really sensitive to usb noise.
When I hook them up to my iMac there's a buzz, my iMac has a lot of usb stuff connected to it.
When I hook them up to my MBP with just one USB cable going to the same dac the noise is gone.
So'll I'll probably get me a Mac Mini to connect my dacs to it and connect to my library via network.
Is the standard Mac Mini model ok or is there any use for more memory or a faster processor?
I might be using it for HD video playback over the network as well by hooking it up to an AV receiver with HDMI.
You might consider a Schiit Wyrd. Might be much less expensive, and you don't need to manage multiple computers.
Also, I believe the imac still has optical out (through the 3.5mm plug), so you can try that.
