BitPerfect (was: Audirvana Alternatives)
Jun 16, 2015 at 5:42 AM Post #781 of 801
Another bit +1 - or just plain +++ - for BitPerfect aka BP.  Just purchased it for my Mac Mini - which is equipped with a small but powerful FiiO E10 and through which I'm listening via Martin Logan Mikros 90 phones - and BP provides subtle but audible improvements - more richness, complexity and body - to the sound my Mac is putting out.
So - Kudos to all the BitPerfect brain trust!
Jun 16, 2015 at 3:10 PM Post #783 of 801
Indeed. If there's one app I I'd hate to live without BP would be it.
And there's another nice one, a true help for late night sore eyes ... "f.lux".  :)
Jun 17, 2015 at 12:54 PM Post #785 of 801
I'll join the positive remarks for BP. For the money, its a fantastic piece of software and does an incredible job of improving iTunes SQ.
I also second, third or fourth the EQ motion for next update
Jun 27, 2015 at 8:08 AM Post #786 of 801
I think gapless playback is no longer working with iTunes 12. The only way now to make gapless playback work is to create a fixed playlist. Is this a known bug? I have any issues with gapless before.
Jun 28, 2015 at 11:32 PM Post #788 of 801
Gapless playback has been deteriorating for a while. The root cause is the iTunes "up next" feature. There is currently no way to ask iTunes about the "up next" list.
The net result of this is, gapless playback can only work if what iTunes reports as the next track happens to match "up next". What iTunes reports as the next track is the order you see on the primary playlist. So if that playlist is sorted by, for example, track name, then gapless won't work. On the other hand, if it is sorted by track number, then by album name, it is much more likely to work.
I'm currently trying to think up a way to solve this problem. The best solution would be for Apple to expose the "up next" list via AppleScript... fingers crossed for an iTunes update (maybe the update that comes with Apple Radio in a few days.)
Mar 10, 2016 at 12:08 PM Post #789 of 801
@agentsim
I now have my music on a thunderbolt drive connected to my computer which is connected via usb to my dac.
Let's say I put my music on a network drive instead (with very good wired network connection)  and the rest stays the same.
Will the sound still be as good, or will there be compression if iTunes (with BitPerfect) needs to get the music from a network drive instead of a thunderbolt drive?
Mar 10, 2016 at 12:12 PM Post #790 of 801
The sound should be pretty much identical, this is how BitPerfect's reference system is set up. Gigabit wired connection to a Synology NAS, and we notice no degradation vs. the built-in drive on a Mac Mini.
Mar 10, 2016 at 12:20 PM Post #791 of 801
@agentsim
Don't forget to get an AudioQuest diamond ethernet cable to make your bits sound better.
http://www.audioquest.com/ethernet/diamond
Mar 10, 2016 at 12:26 PM Post #792 of 801
Thanks, just what I needed to hear Agentsim.
I recently picked up some vintage receivers which are really sensitive to usb noise.
When I hook them up to my iMac there's a buzz, my iMac has a lot of usb stuff connected to it.
When I hook them up to my MBP with just one USB cable going to the same dac the noise is gone.
So'll I'll probably get me a Mac Mini to connect my dacs to it and connect to my library via network.
Is the standard Mac Mini model ok or is there any use for more memory or a faster processor?
I might be using it for HD video playback over the network as well by hooking it up to an AV receiver with HDMI.
Mar 10, 2016 at 12:30 PM Post #793 of 801
We have a fairly old Mac Mini, I don't remember that exact model and it works pretty well, but it is a dedicated audio device. Looking at the specs on the base Mac Mini (1.4 gHz), that seems pretty weak. I'd suggest going for the mid range model (2.6gHz, 8gb ram), that'll be more than enough for BitPerfect and I'd imagine for any HD video you might throw at it.
Mar 10, 2016 at 12:34 PM Post #794 of 801
Thanks Agentsim, my buzz problem is solved then!
Way too much stuff in my mancave. ;)
