agentsim
Member of the Trade. Author of BitPerfect.
- Apr 25, 2006
You can contact support@bitperfectsound.com, that's the best way to get in touch.
Yep, coming in the next version which is waiting for Apple to review it.
thanks for the update!
hows that iOS version going?
Question-does Bitperfect increase audio quality even when playing 44.1 16 bit tracks in iTunes? My system Audio Midi is already set there.
Or is Bitperfect mainly for higher quality song files?
It will work on both low and high-res files. I would suggest you try to use lossless audio if possible.
BitPerfect will change what Audio Midi has configured to best match the file you're playing.
Quote:It will work on both low and high-res files. I would suggest you try to use lossless audio if possible.
But if the Audio Midi matches what I'm playing, BitPerfect doesn't improve anything, right?
Thought I'd add my two cents ...
In my case, you've really nailed it with this version
No issues whatsoever with Mac Mini, 10.8, W4S DAC-2, USB
Nice Job and Thanks
