JIGF
- Jun 23, 2009
I have and keep getting hiccups in the playback in spite of the updates. The best way to get around it is to set a playlist.
I've just received my retina macbook, so I'll be looking to update those icons![]()
I've had all of the versions of BitPerfect, and never had any of the problems mentioned by some in this forum until now. The latest version, 1.03, is behaving oddly. It seems like tracks are cutting off 3 or 4 seconds from the end. Sometimes this just means no silence between tracks, or if there is a fadeout, it ends early and abruptly.
Then, there will usually be a tiny, soft tick or pop, and the next track will start at the beginning. This is happening with all my music, whether 44.1/16, 96/24, etc. No glitches during the playing of any tracks; only the slightly early end, a tick or two, and then the next one starts with no gap in between (Yes, I have always had Sound Check disabled, of course).
I'm using a Mac Mini which is dedicated as a music player, so everything else is disabled, turned off, etc. I'm feeding a W4S DAC2 via USB. I have all of the BitPerfect manual's recommended options selected, and have not changed them. It has worked perfectly until this newest version.
Exact same issues here too.
Up 'til a week ago, I've had no issues running a Mac Mini 10.7.4 USB to Arcam rDAC through several versions of BP.
I just switched to a W4S DAC2 and I get clicks, ticks, pops between tracks. Sometimes the last few seconds of a song get cut off like RJM reported.
Other than those small issues, the playback SQ is great.
I've systematically tried changing most settings to no avail.
Should I revert to v1.02? if so, where can I get it?
or would you like another beta tester Tim?
I was having a think, and it's probably a little far fetched, but it would be great if you could use BitPerfect in conjunction with other apps (selectable by the menu bar icon maybe?) such as VLC and Spotify. Are there any future plans for other software integration like this?
That depends on the app. For video players like VLC, syncing audio to video would be next to impossible to do in an external program. I have thought of doing integrations with other music organizers, but I haven't really looked into it in detail yet.
