xxbaker
- May 31, 2008
viction - The case I'm using is a Hammond Aluminum case that measures 8x12x3 in. It's a pretty good fit. I got all my jacks and switches from mouser.com, I'm sure other people will have other suggestions.
Everyone - I finished putting everything together and noticed that my two 6h6n tubes don't light up. The three other tubes do. I measured heater voltage and it reads: 6.5VAC across the tube pins. That's a little high, could that be causing a problem?
It seems to work, but volume seems a bit low. I need to get up to around 11 o'clock for a decent volume (I don't listen very loud) with the HD650s. Is this normal? NFB is at it's lowest (for highest impedance phones).
Thanks for the help!
