Duckman
- Nov 14, 2008
Well - the CTH is very compact and easy to carry around. But does it drive the T1s well?
Originally Posted by Helmore /img/forum/go_quote.gif Has it even been confirmed that this ground wire is actually connected to the headphone plug of the T1? |
Originally Posted by Helmore /img/forum/go_quote.gif I guess they connected the shielding of the cable to that 3rd cable and you should thus connect it to chassis ground (shield cable) on a pair 3-pin XLR plugs. It would pretty much make the entire signal path, from amp to headphone shielded. |
Originally Posted by musicman59 /img/forum/go_quote.gif I don't think it will have a left and right going to the same driver. Red should be the positive and whit the negative for that channel. The black I guess could be physical ground but where does it go at the plug side since there it just have tip, ring and sleeve (left,right and common ground). |
Originally Posted by Parafeed /img/forum/go_quote.gif Yes. Both channels shield wires and signal returns (white wire) are connected to the plug body of the fitted Neutrik 1/4" plug. Exactly - in a balanced config, green is L+ (pin 2), white is L- (pin 3), shield is ground (pin 1). Right hand channel, red is R+ (pin 2), white is R- (pin 3), shield is ground (pin 1). |
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Originally Posted by musicman59 /img/forum/go_quote.gif Thanks Parafeed. Do you know of any balanced headphone amplifier that is actually using the pin 1 for ground? I all I have seen about makeing balanced headphones cables talk about leaving the pin 1 of the male connector open. If I connect the shield of the cable to the male pin 1 but the female pin 1 in the amplifier is not connected to anything what good will it does? |
Originally Posted by musicman59 /img/forum/go_quote.gif Do you know of any balanced headphone amplifier that is actually using the pin 1 for ground? |
Originally Posted by musicman59 /img/forum/go_quote.gif If I connect the shield of the cable to the male pin 1 but the female pin 1 in the amplifier is not connected to anything what good will it does? |
Originally Posted by drubrew /img/forum/go_quote.gif Looks like the phones are starting to trickle into the US. I am getting a small batch shipped to me tomorrow. It would seem US was low man on the totem pole for these |
Originally Posted by MacedonianHero /img/forum/go_quote.gif The Canadian Distributor got theirs on January 3rd. Granted it was for only 4 headphones and I was lucky enough to be their first customer. I'm glad that we Canadians finally got something first |
Originally Posted by wakeride74 /img/forum/go_quote.gif I don't want to hear it... I'm constantly importing bluray steelbooks that are Futureshop exclusives. |
Originally Posted by neptius /img/forum/go_quote.gif wakeride74 (#1585) - Aha, you solve the same problem as I ... |
Originally Posted by MacedonianHero /img/forum/go_quote.gif I forgot about that one. They are pretty cool. Did you realize that Bestbuy actually owns Futureshop? I wonder why they don't carry the blu ray steelbooks? |
Originally Posted by gbacic /img/forum/go_quote.gif Because we Canadians just appreciate the better things this world has to offer more than you Americans Hmmm. Maybe I should go down to my hifi store and give the T1 a listen. Should I bring my 332? Or would a Heed be better (it's what they have there). |
