DT 1990 Pro EQ Revision 12-05-22
This EQ is an experiment with the Harman Target Curve. It religiously contours to it from the frequencies of 900-8000Hz notably the critical frequencies from 3325-4350Hz. Outside of those frequencies are my own deviations. Here is a graph of the Frequency Response after my EQ overlayed with the 2018 Harman Target Curve:
I did not just follow the Harman Curve blindly but was at one point in fact opposed to many aspects of it until through trial and error and experimentation I found that adhering precisely to it showed me that there is "SOMETHING" about this darn Curve that is right on them money. It seems to have everything you need and nothing you don't. Chicken skin from songs I'd heard 100s of times before!
The sub bass extension is a true one that extends leftward in a straight horizontal line instead of a drop off for true bottomless sub bass impact. 80Hz is emphasized to allow kick drums to cut through the mix and provide punch and slam. 300Hz and 575Hz are emphasized for the top ends of kick drums and the meatier parts of snare drums respectively. The "Beyerdynamic Peak" is eliminated and some added sparkle is present at 14kHz and up.
Channel: all
Preamp: -6.5 dB
Filter 1: ON PK Fc 17 Hz Gain 2.55 dB Q 1
Filter 2: ON LSC Fc 39.5 Hz Gain 4.7 dB Q 0.69
Filter 3: ON LSC Fc 40.2 Hz Gain 0.71 dB Q 4
Filter 4: ON PK Fc 80 Hz Gain 7.74 dB Q 1.41
Filter 5: ON LSC Fc 85 Hz Gain -1.61 dB Q 1.2
Filter 6: ON PK Fc 230 Hz Gain -6.05 dB Q 1.3
Filter 7: ON PK Fc 300 Hz Gain 3.7 dB Q 2
Filter 8: ON PK Fc 575 Hz Gain 2.3 dB Q 4.5
Filter 9: ON PK Fc 750 Hz Gain -0.7 dB Q 4
Filter 10: ON PK Fc 900 Hz Gain 1.55 dB Q 0.7
Filter 11: ON PK Fc 1000 Hz Gain -0.9 dB Q 1.2
Filter 12: ON PK Fc 1250 Hz Gain -1.35 dB Q 0.9
Filter 13: ON PK Fc 2800 Hz Gain -1.3 dB Q 3.2
Filter 14: ON PK Fc 3100 Hz Gain 0.6 dB Q 1.2
Filter 15: ON PK Fc 3650 Hz Gain -0.4 dB Q 5
Filter 16: ON PK Fc 4000 Hz Gain -0.25 dB Q 4.5
Filter 17: ON PK Fc 4250 Hz Gain -4.4 dB Q 6.5
Filter 18: ON PK Fc 4300 Hz Gain 9 dB Q 5.2
Filter 19: ON PK Fc 4500 Hz Gain 2.8 dB Q 6
Filter 20: ON PK Fc 5000 Hz Gain -1.2 dB Q 4
Filter 21: ON PK Fc 5525 Hz Gain -1.75 dB Q 4
Filter 22: ON PK Fc 6200 Hz Gain 1.25 dB Q 4.5
Filter 23: ON PK Fc 6500 Hz Gain 0.6 dB Q 6
Filter 24: ON PK Fc 7300 Hz Gain -7.15 dB Q 4
Filter 25: ON PK Fc 8300 Hz Gain -6.2 dB Q 3.5
Filter 26: ON HSC Fc 12500 Hz Gain -7.15 dB Q 0.8
Filter 27: ON HSC Fc 13500 Hz Gain 4.26 dB Q 1.65
Filter 28: ON PK Fc 19500 Hz Gain 4.35 dB Q 0.5
The amount of bass can be easily tailored to your liking by adjusting Filter 5 to taste and then resetting the Pre-amp value back to -0.1.
I know that there are
a lot of filters and I've been impugned for that on many occasions but I have an anal retentive ear for detail and precision that I can't ignore. With the attached .txt file you can simply import it into PEACE so as not to have to manually enter any values! I've been working in sound engineering for over 25 years and I've never heard sound degradation from EQing. Though I am a proponent of EQing I do not, by any means, intend to convey that you
must EQ. I just like to do it personally. YMMV. Nuff said about that.
So finally, try this EQ out if you're curious and maybe you'll like it! I am not selling anything, I am merely sharing an aspect of this headphone hobby we all love so much! Happy listening!
Blessings,
-Jonne
