ilmothedude
- Dec 20, 2014
My trial n error suggestions when it comes to stuffing the turkey...err pads:
{Apart from angling the drivers}
If i want less resonance/hallishness....i use cotton gauze
Eg. boomy sounding pleatherpads
If i want to add body to a lean sound....i use the firmer foam
Eg...when i have too analytical/thin sounding velorpads
Above are minor tweaks...wont make the $1000soundg dt150 a worldbeater
If u cant hear a diff, just avoid the turkey
I use soft foam stuffings inside my dt100 veours so there's not so much hard surfaces inside pads, and so resonaces are minimum. After that setup I tested pleathers again just yesterday and I found sound to be brighter! Of course bass is more boomy, but not nearly as much as I remembered it to be, and soundstage and imaging are awesome. Overall I do like pleathers sound more than I remembered, comfort not so much tho, but I think I prefer smoother sound of my velour setup.
