NymPHONOmaniac
hum....
look like the Hibiscus cable is findable now:
https://www.aliexpress.com/item/4000297658368.html
Can you say something more about the cable? Is it soft, heavy, prone to tangling? I'm thinking of buying it to replace the one on my IT01, as the stock cable is getting more and more stiff, and the two kind of look alike.Yep, FAAEAL HIBISCUS cable is real BADASS.
There's another listing with only 3.5mm:Thank you for the info! I just found it.
Btw, the link for the Hibiscus cable: https://www.aliexpress.com/item/4000340444755.html
Edit: Damn, no 3.5mm option available
Edit: Nevermind. I just checked and it seems there's no MMCX version...
Wrap something around your neck and get crankin'My Semkarch CNT has finally started singing. I've had the devil's own job getting them to fit comfortably and seal. I've had one or the other or neither but never both. An hour of listening in and I am still feeling no discomfort. Spiral Dots a size smaller than usual have seen me right. Now I need to work out whether I prefer CNT or Blon.
Received my kbear F1 with an unknown driver (no markings on it nor vent, no idea what it is and too lazy to skim the forum) and I'm very impressed on overall clarity and nice timbre on acoustic instruments.
It's not going to win any contest, but it looks, feels and sounds minimal, and I like it because it really doesn't sound off in any aspect, which is what I ask of a budget iem.
This will go to the backpack for now until I pick a single DD. Good job, this is pretty good for a 20€ single BA.
That’s the generic Tehnz 29898 driver. It’s a custom driver developed by Tehnz, so it’s not a clone of any Knowles model.
It’s unvented BTW
I haven't yet but am open to it, any you can name that can suit requirements ?
It looks clownish though
You're thinking of lawyers.yes, it is called - alcohol
