BEST Sub-100$ BUDGET EARPHONES - Chi-fi, Obscure brands and impressions sharing-REFERENCE LIST
post-13182955
Post #1,951 of 25,138
Griffith
On another note, I also received a Sony MH-EX300AP with my Vivo. They were quite affordable and I had seen a very similar-looking model of those Sony earphones being recommended here on head-fi so I decided to give them a try to see if they were similar. Boy was I disappointed... if you are interested I wrote a short review on them which I'm leaving here as a cautionary tale.
post-13187336
Post #1,952 of 25,138
basefi
anyone here happen to have the 1more pistons classic?? it seems that its a re-release of the pistons v2.. wondering if the sound sig is the same with the pistons 2
post-13187376
Post #1,953 of 25,138
Griffith
I do not own them, I have not listened to them but I'm fairly sure that the Pistons Classic do not sound the same as the Piston 2. At least that's what I remember reading on some topics here on head-fi.
post-13187396
Post #1,954 of 25,138
basefi
ohh... which one sounds better?? based on the topics
post-13187401
Post #1,955 of 25,138
Griffith
I believe the Piston 2 are better regarded than the Classics. The only Xiaomi I've listened to was the Hybrid (the first model, not the recent one) and in all honesty I didn't and don't appreciate it's signature response.
post-13187575
Post #1,956 of 25,138
rronald25
Hi,
Im looking for:
> chinese overear headphone
> with inline mic
> closed would be better
> balanced sound
> nice design would be great
> around $50 to $100
Can someone help me with that
post-13187696
Post #1,957 of 25,138
Griffith
  Hi,
Im looking for:
> with inline mic
> balanced sound
> around $50 to $100
I haven't listened to these but they are the ones I would consider in your situation:
Havi B3 Pro: https://www.aliexpress.com/item/HAVI-B3-Pro-I-Dual-Driver-In-Ear-Earphones-IEMs-HiFi/32442592580.html?spm=2114.01010208.3.1.FxGDIz&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10000032_10000025_10000029_10000028_10060_9999_10062_10056_10055_10054_10059_10099_10000022_10000012_10103_10102_10000015_10096_10000018_10000019_10052_10053_10107_10050_10106_10051_10000009_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10115_10116_10037_10033_10032_10000044_10078_10079_10077_429_10073_10000035_10120-9999,searchweb201603_2,afswitch_1_afChannel,single_sort_3_default&btsid=39924ec8-e259-440d-97c8-d31b82db3a50
Vsonic GR07: https://www.aliexpress.com/item/100-Original-VSONIC-GR07-BASS-Flagship-Version-High-Fidelity-Inner-Ear-Earphones-With-Retail-Package-and/32352629410.html?spm=2114.01010208.3.2.gPKVT4&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10000032_10000025_10000029_10000028_10060_9999_10062_10056_10055_10054_10059_10099_10000022_10000012_10103_10102_10000015_10096_10000018_10000019_10052_10053_10107_10050_10106_10051_10000009_10084_10083_10119_10080_10082_10081_10110_10111_10112_10113_10114_10115_10116_10037_10033_10032_10000044_10078_10079_10077_429_10073_10000035_10120-9999_10116,searchweb201603_2,afswitch_1_afChannel,single_sort_3_default&btsid=70713394-ee55-4d7a-8487-426e63d69cd0
post-13187715
Post #1,958 of 25,138
B9Scrambler
London, Canada
London, Canada
Website
thecontraptionist.blog
Haven't heard the GR07 but the Pro 1 is a great suggestion.
post-13187723
Post #1,959 of 25,138
Vidal
Member of the Trade: Asian Provocative Ear
Website
www.aproear.co.uk
Havi B3 Pro:
Vsonic GR07:
Neither of those two have an inline mic.
post-13187742
Post #1,960 of 25,138
B9Scrambler
London, Canada
London, Canada
Website
post-13187748
Post #1,961 of 25,138
Griffith
You're correct, I completely forgot about that. I guess in that case he'd need to get something with MMCX connectors or dual pin...  now that I think about it, I can't think of any earphone in that price range with Mic that I would recommend or be aware of. I'm sure there are plenty, but I just have no knowledge of them. This is an odd situation where if his price range was lower I might be able to make a recommendation more easily.
For example my **** UE have a balanced sound signature, you can couple a Mic cable to them separately but they'd cost him around $30, even with the cable.
I honestly have no idea... all the earphones I could point out are below $50 or over $100.
post-13188019
Post #1,962 of 25,138
Vidal
Website
www.aproear.co.uk
I think you must have the UES rather than the UE at that price, fairly balanced but not a ground breaker in terms of SQ.
Another that might do a job are Moni One, heaven't heard it but from what I recall it could have the right sound. You need to seek out a mic overear cable to go with it though
post-13188059
Post #1,963 of 25,138
Shawn71
Hi,
Im looking for:
> with inline mic
> balanced sound
> around $50 to $100
Ok so whats your current earphone(s) that you love most and any specific genres to go with the sound signature you lookin for?.....coz that way you get more recomendations from many of us here.
you can also check hifiman re-300 with mic and vsonic vsd2si as both are also chinese and ticks most of your need.cant comment on former's sound but latter is not a truly balanced but bit more emphasis on either ends that cld fit most of the genres,if you are ok with that.fits most of the ears so much comfortable on the long listen.
post-13188062
Post #1,964 of 25,138
Lurk650
South San Francisco
South San Francisco
Hi,
Im looking for:
> with inline mic
> balanced sound
> around $50 to $100
EDIT: Yeah he posted in the regular Chinese gear thread clearly stating he wants full size cans
If full size then look here: http://www.head-fi.org/t/822184/chinese-asian-brand-info-thread-on-or-over-ear-headphones/
Yenona Pro sound like they would be a good match.
post-13188116
Post #1,965 of 25,138
rronald25
These are the one i used so far
Sennheiser HD206 love it for the price
Akg K518 I also love it but on ear & no inline mic
Philips cityscape SHL5905 not bad but I only had it for few weeks as I lost it on the train, however I believe for some reason for sound quality I like the previous 1.
Regarding genres thats complicated, I love hip-hop & rock, but rather than only powerfull bass, I prefer clear & crisp sound, so I can also listen to instrumental / opera too.
Ps: so far from ali & amaz I like the design of Riwbox in5 & intone cx-05, both around €25ish
Users Who Are Viewing This Thread (Users: 12, Guests: 20)
