RicardoB
- Oct 10, 2016
Just got a USB host adapter for my Pro 3 so I could do some comparisons.
Subjectively, the stock 3.5mm DAC is way better than the PCM2707 DAC I built a long time ago. In fact, it is almost as good as my OpenDAC HD! (All three DACs were driven from the Pro 3, with the OpenDAC HD connected via a USB to S/PDIF adapter.)
The OpenDAC HD indicator stays cyan, indicating that the output is stuck at 48kHz. That, however, might be a limitation of the USB to S/PDIF adapter I'm using. Even with that in mind, there's no real subjective difference between the OpenDAC HD driven off the Pro 3 and the OpenDAC HD driven off my PC.
Probing around with dmesg doesn't reveal anything about what chip it uses, other than that it's USB 2.0 and is detected as "LeTV LeEco_CDLA_DH1". The scope trace with a 10 ohm load shows no detectable droop but a significant overshoot that doesn't seem to have any effect on audio quality.
There's a little of what I believe to be residual carrier of around 6MHz or so. Not much but it was enough that I had to play with the scope settings to get a stable trace. That combined with the astoundingly small size of the DAC and lack of droop leads me to believe it might not be a traditional DAC/amp at all but rather a miniature digital amplifier using Delta Sigma.
Thank you for this post, so would you say the Pro 3 is worthy to be among the best? Could you compare it to any of the devices mentioned in this thread as having good portable audio?
