angevoi
- Dec 1, 2011
But isn't converting the new port to 3.5mm downgrade the otherwise lossless digital sign? Leeco / Letv looks promising except this unsure factor.
Thanks . i have ordered the OSTRY KC06A . Hope its a match for my Meizu Pro 5.
meizu pro5 continues to impress, its an excellent music player, but a so-so smartphones. i am facing issues with push notification delay with it. else no gripes
Why don't you try custom ROMs?
What rom you use. I recommend latest beta A rom series.
Hi,
I was about to buy the Meizu 5 Pro, but I realized that I still want to have LTE band 20. Thus, the Meizu 5 Pro is unfortunately out.
So here are my requirements / wishes:
- LTE Band 20
- Dual SIM
- SD Card (separated from SIM Slot)
- Outstanding Sound Quality
- OTG (plan to buy a Chord Mojo)
- IEM: Nuforce Primo 8
If I renounce the extra-SD slot, the ZTE Axon 7 comes shortlisted.
Does anyone have experience with the ZTE Axon 7 in combination with the NuForce Primo 8?
I am grateful for any suggestions.
Thanks!
