maxjstern
- Jun 7, 2015
Hi guys, I'm interested in a cellphone with a good DAC. Not looking at iPhones, HTCs or Samsungs because being a father to a 3-year-old means I'm after a not-too-expensive phone that can take a few drops.
I'm looking for one with 5 inches display (or 5.2 max, will never go 5.5 and above), SD card slot and reasonably good battery life. Meizu's MX4 and 5 (non-pro) were eliminated bcos they don't have card slots, which leaves Vivo X5 or Pro. Or maybe, the HTC M8 (much cheaper than the current M9).
Would be playing FLACs and MP3s and connecting the cellphone to IEMs, so I'm not fussy about the amp component. Would like Spotify premium or Tidal lossless too, however I've heard that they will only use the stock phone DAC and not the Hifi DAC. Has this been rectified yet?
Any suggestions would be welcome. Thanks in advance.
You listed almost every option by yourself.
In the case of the V10 the Hi-Fi Dac is used with Tidal. Spotify is just MP3s... I would go solely with Tidal.
Get a M8,install soundmod (DragonFi) and/or Viper4Android...
The Z3(compact or not) would be another option, as it sounds good, but is not that loud, which is not a problem, as you are using IEMs...And the player (software) is extremely good - subjectively, I know!
Hope, I could help a little...
