muad
- Jan 20, 2010
You will not regret the NFB-12 with either the hd600's or the HD650's. I have the Audio-gd Fun which has the same sound quality and power as the NFB12 and it definitely does the HD650's justice. The thing with the HD650's is there is a noticeable treble roll off and a slight mid-bass hump. I would not say the HD650 is bad for classical but I'm not sure how it compares with the HD600. With classical I find the HD650 really brings strings to life, bassier instruments have power and the piano sounds real. The entire orchestra has body and has a sense of grandness to it. Where it loses out is with recordings that rely on anything above 10,000hz. The frequency is there, its just more in the background than usual. I have the new version and I don't regret it. I do wish i could compare the hd600 with it. From everything Ive read it would a downgrade for me, as I like the amazing detail (although it's not in your face) and instrument separation. Unlike the K701 where the instruments have more space between them, the HD650 is more intimate and yet it is very easy to pick out separate instruments. Some of the best separation I have ever heard, although I admittedly haven't heard many top tier cans.
BTW if you buy the headphones new they will be the newer versions. The cheapest price for the HD600 and HD650 is on ebay @ 290 and 335 respectively. The ebay seller Razordogdeals is an official sennheiser dealer. So you get full 2 year warranty.
