bogginhead
Banned - AKA Lee McDonaldUnreturned Tour Gear, Sells Borrowed Gear, Incomplete Trades
Anyone here possibly willing to trade some small Symbio W's for some medium and large pairs? I have at least 3 pair of medium and 1-2 of large.
You should be able to find eartips like that on Amazon and Aliexpress.=) They sound exceptional on my niceHCK M6, as well as the FLC8s, so yeah, I use them daily for the last 2 years.
Thanks, I have looked, and even ordered some, on both Ali and Amazon, and they are not the same. But I keep looking!You should be able to find eartips like that on Amazon and Aliexpress.
Thanks for the info -- I already have the Senn's and they arenot quite right; as for the X5 -- I have spent more on Complys that I dont use so much than 13.00 and get a X5 in the process. Sounds like a plan. Thanks.You may be out of luck finding them separately. I looked through all the silicone tip listings on AE not too long ago and don't recall exactly those being for sale. But I see the x5 for about $13 on AE... So not too bad. Maybe giveaway the iem as a gift?
There is the sennheiser style double flange tips that are a shallower fit but do have 2 flanges the same diameter. And cheap, about 1.50 shipped for the set.
Has anyone tried inserting Comply foam into a Symbio tip? Is that a crazy idea? I feel like the Symbio foam is too rigid and won't expand in my ear canal.
As things stand, neither Comply/Symbio are working for me so I may as well get creative with them.
