Jmop
- Sep 17, 2014
Are there tips with the same mechanics as SpinFits for 5mm ("wide") nozzle diameter? I like how the "spin" effects soundstage and am just curious about other options.
Thank you I'll check out my options with Amazon in UK.I've always bought them from Amazon Japan: shipping (to Italy) is fast and not excessively expensive.
Spiral dot ML is approx 13mm and L is 14mm. you can decide based on Spinfit size. hope it helps.A question about Spiral Dots: If I am a large in spinfits, will I also be a large in Spiral Dots?
They look somewhat similar to Sedna Short but it's hard to tell with them in the package. Is it a medium or wide bore? Any Commen on how they compare to the Azla?
Very nice eartips from Radius.
Midium-large bore.. It has better treble than Azla Sedna short for me. It seals like a custom eartips or maybe even tighter. gives almost reference level of mids. bass is very tight and textured as well. recommended. Bought from Amazon JP.They look somewhat similar to Sedna Short but it's hard to tell with them in the package. Is it a medium or wide bore? Any Commen on how they compare to the Azla?
I was trying to find these as well.While browsing one the good source on eartips on the internet I came across this ALPEX Hi-Unit HSE-A1000 eartip. The blogger bought it from Amazon Japan, but I am not able to find it in amazon or anywhere. I wrote to the blogger and requested for amazon link. There is no response. It's been more than a month now. I commented on the blog but comment was not published. Please let me know in case anyone finds this eartip
website link:
https://www.audioreviews.org/guide-to-iem-silicone-eartips/
Extract from the blog:
Bore size: wide
Stem length: short
Feel: soft and pliable
Bass: 4.25
Midrange: 4.25
Treble: 4.50
Soundstage: 4.0
Vocal presence: 4.25
These wide bore eartips bear an uncanny resemblance to JVC Spiral Dot in look but they don’t sound alike. The HSE-A1000 is brighter, more open and livelier. Midrange has more sparkle and life. The bass is cleaner, tighter and more textured. Best of all, they cost only a fraction of the JVC. I am surprised how good these are. What a hidden gem!
Purchased from Amazon Japan
https://www.amazon.co.uk/JVC-EP-FX10-Spiral-Dot-Earpieces/dp/B08KSJNWRX?th=1Anyone know where/how to source JVC Spiral Dots ++ in the UK? I've got some of the older variant from PenonAudio and love them, would be interested to see what the differences with new ++ are.
Final Audio Type E!!Using Kz Zas, which eartips is good for bass?
Any idea if tws version works rather than regular ones?Final Audio Type E!!
Just got these and boy do they deliver, just what i was looking for!
