JPresz
- Dec 4, 2010
a good budget amp/dac combo for the K701 is the e7/e9. the combo should run you under $250
The K702's are perfect candidates, they sound like real life.
Quote:The K702's are perfect candidates, they sound like real life.
Yes, they do...sounds much more balanced compare to the DT-880, and a great upgrade over HD-600.
Thank you very much for all the help,
After all your comments, and reading reviews on Head-fi, I've narrowed my decision to two options for my budget and needs, I will be making the order this weekend or early next week. This will be my first step into the world of quality audio. Just to let you know, my source will be my Macbook Pro, and the Apogee Duet sound card.
AKG k701 ($350) and Schiit Valhalla ($350)
or
Sennheiser HD 600 ($400) and Schiit Asgard ($250)
Any thoughts or comments between the two choices before I make the order?
Do you live in the U.S.? You can find the AKG K701s for around $260 easily on eBay, and the HD600 are like $300.
Yes, they are much cheaper on ebay?!? I got my headphone prices from Sweetwater.com. But are the headphones on ebay the real thing? How can they afford to be much cheaper? I had always done my shopping from sweetwater, thinking they were the most fair price. I can buy a second headphone or amp with the money I save!
Ok after many many hours on headfi, reading and reading, and fantasizing, I've settled: AKG 702s (incase i want to upgrade to a new cable later) and schiit Valhalla tube amp.
My set up will be:
itunes (apple lossless) > apogee duet> Schiit valhalla > k702s.
How does this sound to you guys? Any suggestions? Do I need a DAC or a cable anything else?
