jordannn15
- Sep 9, 2014
http://www.amazon.com/iSimple-Dashboard-Mounting-iPhone-Lighting/dp/B00GP3PB4G/ref=sr_1_1?ie=UTF8&qid=1412135925&sr=8-1&keywords=lightning+to+rca
$50
I'd say... no cheap options.
Well there is
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=897273&gclid=CMzQ-bzJisECFTDl7AodYyUAYw&Q=&is=REG&A=details
which you can use with
http://fiio.com.cn/products/index.aspx?ID=100000049935442
The Fiio E18, with the USB Camera to Lighting adapter is your best option if your wanting to connector, to your PC, your Phone and your xBox. Ofc it costs more
and it doesn't have Optical In so you won't be able to use it to act as the Dac for your xBox as well. So you could, use the xBox aseccory and use the RCA outs on it to go 3.5mm into the E18, and then use the E18 with your PC and Phone via USB
Okay I think I may just have to not worry about using it with my xbox because it's more work than what I am going to get out of it but thank you very much for the options you have provided!
As for the iPhone situation I hate this connector but again as you said it costs much more for any other solution. Would it work if I were to get a lightning to mini/micro (whatever the e17 uses) usb cable? It would be the same as going from the e17 mini usb to usb as if I were going to plug it into the pc but instead into the iPhone I would assume.
