dailysmoker
M50 and DT770 are studio monitors so pretty neutral in sound,WS99 is more bass heavy but still with good mids and highs....
Okay, I'm still not sure which I should get out of the ath-m50x, ath-ws99, and dt770 pro 80 ohms so I am going to make a list of priorities from most to least important and then hopefully that will make it easier for you guys to tell me which I should buy.
So from most to least important:
1. Good for rap/hip-hop as this is all I listen to
2. Very good bass without making mids and highs sound bad
3. Has velvet/velour earpads or can be replaced with them
4. Can be driven with Fiio E07K as I will use this with my iPhone
Not to say that number 4 on the list is not important but the others are a little more important. These don't have to be extremely portable but I do not want to have to sit down somewhere just to be able to have a good listening experience. Hopefully this will make it easier to tell me exactly which ones to get. Thanks!
1. M50 - these cans can thump.
2. M50 - for the same reason as 1
3. DT770 - but the M50's are reasonably comfortable. Don't know if the pads can be replaced.
4. I'm pretty sure all above will work with the e07k.
That's IMHO of course. I'd let you try mine but I have a feeling you are very far away from Cleveland Ohio!
Okay I have decided to go with the ath-m50x's and am about to order them and the Fiio E07K. If someone could please quickly tell me how much of a difference there will be if I use a line out cable such as the Fiio L9 vs if I just plug it into the 3.5mm jack? Also should I get the E07K or a different portable amp/dac or just portable amp? Also one more question, how can I use these headphones (just for listening not for a mic obviously) with my xbox 360?
Start with this
it's like $2.50 and it has an Optical and what appears to maybe be a Analog Line out
http://www.monoprice.com/Product?seq=1&format=2&p_id=7526&CAWELAID=1329454627&CAGPSPN=pla&gclid=COvA5fe7isECFTDl7AodYyUAYw
maybe get the Fiio E17 which has optical in so that you can use it do also Decode sound coming from your xBox and drive better headphones in teh future
I was thinking about how either the e07k or the e17 connects to a pc through usb to be used as a dac would it work the same with my 360? Just plug it into the usb port on the front of it? Oh and thanks for the quick answer and recommendation!
Well with a PC yea usb will work, with the Xbox 360, I'm really not sure. That link I sent you came from the Micro Soft page for Xbox 360, it should work as it what they recommend. I dont have a 360 so I can tell for my self, but Mono Price cables are super cheap and built SUPER WELL, Mono price makes a VERY GOOD cable, for not a lot of money. Bout the only MAGICAL thing here on head fi, so get the adapter and a Toslink Cable about 6 feet and throw in a 6 foot Rca to 3.5mm and Rca to Rca while your at it. You can get about 20 feet or so of quality cable and interconnectors for under $20 shipped! If you went to wal mart, you'd pay $20+ bucks for one of those
any who, the E17 is going to be Fiios only option with Optical In and will give you the best sound, the E07k with Rca to 3.5mm from your xbox [with that little adapter thingy] will give you Better sound
and if you just run a 3.5mm to 3/5mm cable from your headphone out to the input of the E07k you would get sufficent sound
Great information! Okay now I have one more "problem," since I have an iPhone 5c it has the lightning connector instead of the old 30 pin. I would like to bypass the iPhone's amp and use the e17 like I have said. Is there a lightning to 3.5mm cable or something I can use to do line out to bypass the iPhone's amp? I have used a 30 pin to lightning adapter but I HATE it. Is there another solution to this?
