Replying to this would be a copy/paste of what I read on other forums abd I dont want to do this ! I never heard the other two so I cant really help you sorry !
I have looked at a couple reviews of the 580's and I have seen some asking if it is worthwhile to upgrade to the pro 900's. So my question is which one should I go with if I were to switch? Also I have looked into high resolution audio players such as the iBasso DX50 and was wondering what the best one would be for under $300?
In terms of value the 580 wins hands down but if you love your bass then the pro900 is a great upgrade if you can get it at a good price. The dx50 is the best imo, great sound quality, great battery life, supports the largest microsd cards, user replaceable battery, has usb otg support and can be used as a dac for your computer.
Okay thanks for all the suggestions now I just need a little vote between the ath-m50, dt770 32ohm, and dt880 32ohm. I know the 880s are semi-open but thats okay. Also I think I might get a decent portable amp with any of these if it will make the sound better, so suggestions for portable amps would be nice.
The ath-M50's are the best bang for the buck. A bit bass heavy but it sounds like that is what you are looking for. I don't think there are velour pads for it but they are very comfortable. Unfortunately mine bit the dust when my 4 year old became obsessed with the coiled cord (I had the older version without the plug in the headphones). Sad day. Might have to get them again as I sit here and think about it....
