Octave0
- Nov 14, 2016
Best free music apps I like are hibymusic & captune, captune is my new favourite currently try it guys. Ui is pretty crap but sound quality is amazing, atleast for me tried so so many.
An update of HibyMusic has been released!
Hiby Music Player is a free lossless HiFi audio player which is designed for audiophile and music fans. User may play DSD files from net driver (like Dropbox/DLNA/LAN) directly with native DSD support.
What's new:
1.Start speed improved
2.Native support for DSD5.6
3.Support for 24bit
4.Lyrics support
5.Better adapted to DAC
6.Download&delete sound plugin supported
7.Switch DAC software&hardware volume manually
8.Rename and remove playlist supported
9.Customize download directory supported
10.Added car-machine mode
11.Added error report
12.Removed exit function when returning
13.Modified LAN path display
14.Modified a direct jump to the play page after clicking song
15.Bugs fixes
16.Android 7.0 supported
Download on Google Play: https://play.google.com/store/apps/details?id=com.hiby.music&hl=en
Power amp alpha version is working great on s7 edge...sound better than all players..now i can use my phone as source without harsh.thanks god
Its the link
http://www.apkmirror.com/wp-content/uploads/uploaded/5748e8ef87023/com.maxmpz.audioplayer_alpha-build-704-uni-704_minAPI9(armeabi-v7a)(nodpi)_apkmirror.com.apk
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
@tbritton Is there a button to open the app from the play store then?
Its the link
Are there any apps that can connect to my NAS at home? I have a Synology, and while they do provide the DS Audio app, I'm looking for other options.
@Joe Bloggs Sorry I meant access my NAS that is physically at home, while I'm away. Say at work, so it won't be LAN. Would need to access it over wifi. From the looks of it Hiby only supports playing over LAN?
No it supports over wifi. LAN is just the name for accessing these stuffs.
I would recommend getting an Amazon or Google Music thing going on for your collection if you want to listen from work to your stuff.
The Amazon storage permits a huge, huge, huge amount of storage (250,000 songs) for around 25-bucks per year. You can upload up to 250 songs to Amazon's "My Music" for free to try out the service first.
Here is the list of supported file formats: .mp3, .m4a
For these file types, only eligible files that match Amazon's catalog can be uploaded: .wma, .wav, .ogg, .flac, .aiff
For Amazon, I use Foobar2000 to convert my files to .mp3 at 256kbps just for uploading, then get rid of those temp files.
Google Play is free, for that part. Upload using Chrome or upload using their app for PC or Mac. Here is the link to the Google Play Music storage limits, currently set at 50,000 songs.
Here is the list of Google Play supported file types: .mp3, .aac, .wma, .flac, .ogg, DRM protected AAC (.m4p), ALAC (.m4a)
Some music file types, including WAV (.wav), AIFF (.aiff), and RA (.r) can’t be uploaded to your library using Music Manager or Google Play Music for Chrome.
For Google Play, I use Foobar2000 to convert my .wav files to .flac just for uploading, then usually get rid of those temp files.
Google has the highest streaming bitrate at 320kbps, with Amazon at 256kbps.
Terry
Very good to know, though it seems like I may just keep with Synology's DS Audio app as it lets me stream lossless. Is there no way to force stream FLAC on Google Music? It's always transcoded to MP3?
