FullBright1
I'll second that. Look no further.
^^^^^^^^ Fact
The result of Japanese craftsmanship and expert engineering :
- Japanese craftsmanship: Each housing is carefully hand assembled in Tokyo
- Tungsten-coated diaphragm provides high rigidity for an improved transient response
- Integrated driver unit design combines diaphragm, voice coil, baffle and magnet in single unit to reduce unwanted vibration
- Each pair of headphones is individually identified by a laser etched serial number and comes with a specially designed hard carrying case
- Newly developed Core Mount Technology places driver unit in optimal position for improved airflow and excellent full-range audio reproduction
- Magnesium frame results in rigid, thin, lightweight construction
- New honeycomb-punched housing design blocks side ventilation to prevent undesirable air pressure loss
- Luxurious Alcantara material used on earpads and headband, providing amazing comfort and durability
- Detachable 3.0 m (9.8') cable with A2DC (Audio Designed Detachable Coaxial) connectors at the headphones and 6.3 mm (1/4") gold-plated stereo plug
