Beoplay E8
Sep 25, 2018 at 3:47 PM Post #392 of 581
Anyone having problems updating to 6.0 firmware? I have 5.6 on my E8s but noting newer appears in App.
Would reset help? I am not sure but I believe I had to do it for one of the earlier updates.
I was not aware that anything newer than 5.6 was available. How do you know there is a 6.0, the app on my iPhone doesn’t show anything ?
Sep 25, 2018 at 3:58 PM Post #393 of 581
Sep 25, 2018 at 4:05 PM Post #394 of 581
If you look at support page:
http://bogo.custhelp.com/app/answers/answer_view/a_id/15395/~/how-do-i-update-to-latest-software?
you can see that 6.0 is written as version number. I probably am wrong but that is how I read it.
Hmm I don’t know how I would interpret that. I would have guessed it was the version of the Beoplay app and not the firmware as it states it supports many different products and I highly doubt the same firmware can be used for all those products, but the version of the iOS app is 2.6.1 from 14th September
Sep 27, 2018 at 3:14 AM Post #395 of 581
Oct 1, 2018 at 11:04 PM Post #396 of 581
Actually, the 6.0 is referring to the document revision number. I don't think there's been a 6.0 firmware release yet. I'm always looking forward to these firmware updates myself, but mine is still on 5.6.0 as well.
I was freaking out cause I didn't have the update icon, but it seems that the webpage is not correct. Good.
Oct 15, 2018 at 3:12 AM Post #397 of 581
How are people finding how long the case holds a charge for? I’m finding it is being reduced. I put them on this morning and the right earbud turned on and worked but the left one is dead. I put it back into the case and nothing. Piece of crap.
Oct 15, 2018 at 3:13 AM Post #398 of 581
And another thing I noticed and feel free to try it and report back is a popping noise when listening to Drake’s “Hold on I’m Coming Home” both on Tidal and on iTunes. The song is fine up until there is say less than 2 minutes remaining on the track.
Oct 15, 2018 at 3:20 AM Post #399 of 581
I get 10–12 hours in total from a fully charged case but for some reason the left unit does not turn on if removed from a fully discharged case even if there is plenty charge in the left unit itself
Oct 26, 2018 at 5:39 PM Post #403 of 581
Any recs on tips or attachments that help keep these in your ears? The large silicone tips sound best of those that were included but they can slip out pretty easily.
I use the JVC Spiral Dots on mine and they stay in good with medium to light activities. I have never used them at the gym just chores around the house.
Oct 26, 2018 at 5:41 PM Post #404 of 581
I use SpinFits
Oct 26, 2018 at 8:21 PM Post #405 of 581
Hey guys looking into these e8, have b&o fixed some of the problems with firmware updates? Or are there still some problems.
