Hi everyone!
Long time reader / first time poster here on Head-Fi.
A big thank you to all members for sharing your knowledge and experience.
Having said that, I want to comment about my experience with the E8's.
I bought the "Racing Green" a couple of months ago and I quite happy.
I previously owned the SE535 (first wired and later with the bluetooth cable).
I find the E8's much better sounding (compared to the wireless sounding Shure), with no hiss (unless the Shure's).
Also the Shure's "Low Battery" voiced-warning was unbearable.
I did experience the issue of the left earphone turning off before than the right one. It happened 3 times in a row,
so I decided to charge only the left unit until the green LED was on, later I did the same with the right unit. Unsurprisingly the left unit charged in 1h:30m and the right one in 0h:25m. After I did that procedure I never had the issue again.
I also suffering from some dropouts (both left and right) when using them with the iPhone XS, no issues before with the iPhone X.
The overall build quality of these seems great, however the paint in the charging magnet started to peeling off.
One member in this thread mentioned this as well. I have this on both units, also on my GF's ones. I cannot upload pictures yet, but I will as soon as enabled to. I'm attaching a review picture that shows the issue.
I'm curious about if this happening to other users as well. Sadly both the pink and the white editions comes with the magnet in natural finish instead of being painted, so they won't suffer from this.
I have an open case with the customer support at B&O. However they cannot assure that I will get the same color. I'm not sure if I got a faulty (2 really) unit of is something more spread, since this post. Thank you for your help!
