Mochan
- Jun 3, 2009
You and your wife must have bionic ears, no make that Bionic Mk VIII Ears, my hearing is good but I can barely hear the leak in the same room a few meters away from these cans, much less in the next room.
You do seem to play really loud, though, 70% on iTunes is really loud for me. I usually only play at about 30-40% in iTunes unamped. Still, I just tried at your listening volume and it's still not audible outside the room.
I think someone suckered you into buying an XB700 but they actually swapped the drivers with loud speakers hahah.
You guys are nuts. These things leak big, not as bad as the Beats but still a lot. I am just playing iTunes from my computer volume half to 70% depending on the song. I had my wife put them on and I went into the bedroom and it is just like she said. I can hear very clearly what song is playing. There is no way I will be able to take these on a plane. On a side note I did the same test with the KOSS PortaPros and they are not quite as loud but not quieter by much.
I can't see how you can claim that the XB700 headphones can't be heard in another room unless you listen at such low volumes that you would not ever need an amp anyway. Or you have such bad hearing in which case you should just sell your good headphones cause you cant hear worth a heck, lol.
Anyway I like them but I will have to use the Klipsch S2's for the flight as well as at night I think. I did order the M50's and the HFI-580's today so I will see how those work out when I get them.
There should be a spec for this, kind of like isolation but in reverse. Just because your phones isolate and you can't hear ambient noise does not mean that other can't hear your tunes with the same dampening as isolation. It would be a good spec I think. Say if you wanted headphones that you could use in a library or something.
