Copyright
- Nov 10, 2008
Using Windows 7. Right now im using just my headphones but waiting on my cable to come in to connect my AV40's. Might throw a small sub into the mix. I think its cool you can set a cutoff on the headphones for the bass. What I dont know is the slope they are using on that cutoff and will I have this option to cut the low freq going to my AV40's? This would be really neat to let the sub provide bass and stop the AV40s from going into distortion early because of heavy bass tracks. I am fairly familiar with car audio using crossovers etc. Thx for any advice. Now that I turned off CMSS3D it sounds almost a little to laid back. Seems like CMSS3D helps gaming though. I will download Foobar.. is it better then winamp? I normally just use Windows Media player lately. Part of me wishes I had gotten the Forte but not sure if the amp is as strong on that one and the upgradeable OPamps sounds like some mod fun
Wow.. dual 627 is pricey. The dual socket is wider on this one then the one on page 10 of this thread. Is a single 627 still an upgrade?
http://cgi.ebay.com/Dual-to-Mono-Opa...item53da79d0a1
Originally Posted by ROBSCIX /img/forum/go_quote.gif What are you using for your output plugins? Are you using foobar or winamp? What OS? |
