kumaiti
- Feb 23, 2010
Is it possible to route the Analog input directly to the amp, bypassing ADC > DAC conversion?
Originally Posted by kumaiti /img/forum/go_quote.gif Is it possible to route the Analog input directly to the amp, bypassing ADC > DAC conversion? |
Originally Posted by ROBSCIX /img/forum/go_quote.gif It would depend on how the card handles analog input. However, most cards will allow realtime monitoring. Just listening to the analog input without and undo processing. |
Originally Posted by kumaiti /img/forum/go_quote.gif Any chance you could test this? It would be a wonderful way to cheat it into working as a "standalone" amp for external sources. |
Originally Posted by JulienS /img/forum/go_quote.gif Thanks, ROBSCIX! |
Originally Posted by ROBSCIX /img/forum/go_quote.gif I just tested to make sure. I set the Flexi-Jack to line input. I connected up a Mp3 player I had using 3.5mm to 3.5mm and I hear the music over the headphoner which are connected to the headphone amplifer. I wouldn't call it cheating, most soundcards work in a similar way Allowing you to direct monitor the input as I use alot of external gear on soundcards and external devices so I use the line inputs all the time on different devices. |
Originally Posted by ROBSCIX /img/forum/go_quote.gif It is not a feature I use often. I consider this feature to be similar to the monitor feature on mixers. It is really just there to check the signal....nothing fancy. Just so you can monitor the input. When I check ed the monitor on the Bravura, there was no noticeable distortion, it may have been there but not to the ponit that it was easily heard. Thanx for the info. |
Originally Posted by JulienS /img/forum/go_quote.gif I'm using this card for a few days now, and I think it's breaking in, it's quite strange but I'm enjoying a very pleasant analog-like sound, it's like I'm listening to tapes, honestly. Those guys from Auzen seem to know how to do it. And the difference from this card to my old X-Fi Gamer is like from heaven to earth, it's like the Bravura is in a totally different and higher league. I'm so pleased with it. |
