XLR produce more power than SE 6.3mm.I have noticed that the "overheated" is only on xlr port, if I use 6.3mm or 3.5mm the temp decrease and fixed until 66 Celsius
Aune S17 pro
- Thread starter music_man
- Tags
- aune aune s17 pro
bogi
- Mar 16, 2013
If you can use XLR port too: How do you perceive sound difference between XLR and 6.3?I have noticed that the "overheated" is only on xlr port, if I use 6.3mm or 3.5mm the temp decrease and fixed until 66 Celsius
XLR sounds more powerful, stop.If you can use XLR port too: How do you perceive sound difference between XLR and 6.3?
![Rolling on the floor laughing :rofl: 🤣](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f923.png)
However, actually I have a Focal Clear MG, an Audeze lcd xc and a Hifiman HE1000SE. I have a Ferrum oor+hypsos as a amp. So...Clear MG and lcd xc sounds better on Oor, but Hifiman HE1000SE sounds much better on Aune!
monkey4054
Disclaimer: I may be half deaf due to too many concerts without ear plugs.. It definitely has 'enough' power to get them loud, but it's definitely not the best or most ideal amp for those few headphones: 1266, HE6, Tungsten, Susvara.My HE6se v2 has never sounded better than on the S17 Pro at volume 44. Never experienced clipping or distortion with any headphone on any realistic volume level.
monkey4054
To comment on temps. My unit is usually sitting at mid-50s, 54-56C usually. That's living in the hot part of Australia, with ambient temperature ranging between 23-28C in my room. I haven't seen it go above 60 even in 100mA high gain, volume near max with my 1266 TC.My unit runs at 63C at idle on 100ma with the room at 16C. High or low gain is the same. Sitting on my desk with nothing else near it. It doesn't change much when playing. Maybe 64C. It is sitting all by itself with nothing else near it. The Aune S17 should come with optional tall feet. It will recover to 53C on 50ma after a few minutes and then down to 45C after a few hours. It does sound better on 100ma.
monkey4054
Gustard A26 currently, I think 5V output balanced from memory?You and monkey4054 may use DACs with different voltage level outputs. And then different people listen at different volume levels.
bogi
- Mar 16, 2013
That's more than 'normative' 4V. You probably really require much louder listening levels. But I agree that power hungry planars, when underpowered, may sound enough loud, but they don't sound as they could - they are for example not able of fully articulated impactful and clean bass.Gustard A26 currently, I think 5V output balanced from memory?
bogi
- Mar 16, 2013
So it looks cooling is designed enough efficiently for uninterrupted 100mA playback, but some units have a cooling issue.To comment on temps. My unit is usually sitting at mid-50s, 54-56C usually. That's living in the hot part of Australia, with ambient temperature ranging between 23-28C in my room. I haven't seen it go above 60 even in 100mA high gain, volume near max with my 1266 TC.
rupert3k
- Mar 20, 2013
down under flute music, lessgooo..!!To comment on temps. My unit is usually sitting at mid-50s, 54-56C usually. That's living in the hot part of Australia, with ambient temperature ranging between 23-28C in my room. I haven't seen it go above 60 even in 100mA high gain, volume near max with my 1266 TC.
Australia is different, I suppose. I live in Europe, maybe my unit got no problem in AustraliaSo it looks cooling is designed enough efficiently for uninterrupted 100mA playback, but some units have a cooling issue.
bogi
- Mar 16, 2013
That would mean you got Australian unit. Those have to be operated upside down on north hemisphere.Australia is different, I suppose. I live in Europe, maybe my unit got no problem in Australia
Disregarding the issues with the jumping volume control and lack of total gain in my malfunctioning unit (how is it that I am normally listening to efficient Ananda Nano at settings above 56 out of 63? with either of 2 dacs?), my Aune S17 sounds really good. Wide, deep sound stage with nice air. good detail, in fast attack and reverb tails. great control and extension in the bass. Fleshed out instruments and vocals with clear separation. I was however inclined to build a slow roll in of a few db of high treble lift eq starting above 7k to bring up the air and snap of drum kit compared to the brighter sound of the amp section of the IFI Zendac2.
Comparing the gain and bias settings, It sounds noticeably better on low gain. Slightly more spacious and blacker between the the images. High gain brings the vocals and center image fatter and more forward in the mix with slightly less balance of the detail to the far edges. There is only about 4.5 db difference in matched level between high or low gain on my amp.
There is much less difference between 100ma and 50ma and is most noticeable on material with big transient peaks which hold their substance and separation better on 100ma. Less dynamically demanding tracks would be very hard to AB the difference. I measured the draw from the wall at 27 Watts on 50ma and 38 Watts on 100ma. It didn't really change between playing hard or at idle. Maybe 1 Watt.
I am going to send my S17 back to wait for a few months until Aune tells us they have the bugs worked out (my unit also arrived with a cut in the item presentation box which all audiophiles know knocked a substantial amount off of the resale value right off the bat which is reason enough for a return and reorder in any event). And have ordered an Topping A90D to have on hand in the meantime. To compare. And as a back up. One for the other. Since they both have a questionable reliability right now. I wish there was a way to just tell the Aune store at Amazon USA that i would be happy to keep this S17 and save them the trouble of taking it back to refurb or scrap it, if they would give me a partial refund. I am a mad scientist DIY Audio modifier for 25 years and would love to diagnose these issues and see how much even better it can sound with some DIY mods even if the volume control would take the output of the relays off the board to a few big steps through even better sounding discrete resistors with fine control via the Foobar player Which I am already using in small amounts anyway. Bypass or replace any of the Wima caps in the direct signal path with full size foil types.
If anyone has one of these faulty S17 they are stuck with and is tired of the issues, I would be happy to buy it for $400.
I fully expect Aune to reduce the pricing of current in stock S17 to $600 to clear them out in advance of a rapid issuance of a V2.
However by putting four aluminum feet 4cm wide and 2cm high and placing it on a raised perforated aluminum grille, my Aune doesn't go above 62 Celsius, all balanced, 100mA, high gain, with all headphones. Aune could therefore simply put much higher feet. For me the discussion ends here. I no longer have any kind of problem.
Total: 16 (members: 2, guests: 14)
