snip3r77
- May 13, 2010
Just wondering if anyone has toneking tk88 as I managed to test this today
I have the TK16S which is basically the T88K but replacing the bass BAs with a DD.Just wondering if anyone has toneking tk88 as I managed to test this today
4.5mm same size tips that fit the bgvp dm6 and all fiio's work fine on my T800'sI find myself speculatively eyeing the Westone silicone tips sampler pack on Amazon (and being simultaneously mildly amused that the silicone+foam sampler pack costs the exact same price and mildly annoyed it's not in stock atm even though I doubt I'd be happy with any of the foam tips anyhow)... Should play around with what I've got on hand already first, but anyone know if they'd fit the T180?
Also messaged Audiosense on Ali asking about the nozzle diameter and got responses saying their "standard tips size is 3.0" and "AT100". That translate into anything useful for someone more familiar with these things? is the 3.0 millimeters?
The T180 is well designed. It's shaped like it was made by God for an ear canal. It fits inside perfectly.I find myself speculatively eyeing the Westone silicone tips sampler pack on Amazon (and being simultaneously mildly amused that the silicone+foam sampler pack costs the exact same price and mildly annoyed it's not in stock atm even though I doubt I'd be happy with any of the foam tips anyhow)... Should play around with what I've got on hand already first, but anyone know if they'd fit the T180?
Should I ever get the T800 I'm sure it will, but right now I have no real motivation to get anything more expensive than my IE 40 Pro for mobile usage.4.5mm same size tips that fit the bgvp dm6 and all fiio's work fine on my T800's
I hope that helps.
It's definitely comfortable, I'm just not entirely satisfied with the stock tips (much like @Slater) and Westone/Shure seem to have super skinny nozzles too which is why I was wondering if anyone knew whether they're compatible.The T180 is well designed. Its shaped like it was made by God for an ear canal. It fits inside perfectly. Foams dont work for me and ruin everything.
It's the smallest nozzle size we will probably ever see and somehow it just works perfectly.
I recommend the T180 for people who dont own a lot of iems or want a couple models from each big brand, or just everyone. Lol.
I would just buy a set of every pair of ear tips you can find. Once you buy a set of iems, you keep buying more... and the more ability to change it, the better that iem could possibly become.It's definitely comfortable (T180), I'm just not entirely satisfied with the stock tips (much like @Slater) and Westone/Shure seem to have super skinny nozzles too which is why I was wondering if anyone knew whether they're compatible.
How does this compared to audiosense?I have the TK16S which is basically the T88K but replacing the bass BAs with a DD.
I am not an expert head-fier by any mean and only had a LG G6 to plug them into at the time. The T800 gave me some harsh treble and sibilance, which resulted in me selling it. However everyone here reports better sources fixes a lot of the issues. The TK16S is warmer and actually got less boomy bass despite the DD. Because of that the mid and vocals sound more forward. It gives me little to no siblant but I can hear the same details in the treble just not as forwarded. But keep in mind I only listened with a LG G6. At last, one significant different for me is that the TK16S is huge compare to the T800 making me also listing it for sale currently.How does this compared to audiosense?
Unfortunately, If you want to buy high end audio gear you need more than one audio source. As you found out, not all sources work for all earphones.The T800 gave me some harsh treble and sibilance, which resulted in me selling it. However everyone here reports better sources fixes a lot of the issues.
Yeah the T800 and LG G7 doesnt really sound much better than the KZ Zs10 pro with the LG G7, totally not worth 300 usd with that combo. But with the Fiio M11 the T800 is godly and absolutely worth it.Unfortunately, If you want to buy high end audio gear you need more than one audio source. As you found out, not all sources work for all earphones.
It's likely due to being BA varying impedance across the spectrum with G7 being 35 ohms output impedance.Yeah the T800 and LG G7 doesnt really sound much better than the KZ Zs10 pro with the LG G7, totally not worth 300 usd with that combo. But with the Fiio M11 the T800 is godly and absolutely worth it.
Oh I see, learn something new everydayIt's likely due to being BA varying impedance across the spectrum with G7 being 35 ohms output impedance.
Fiio are generally near 0 output impedance. $99 Shanling M0 has .17 ohm outpit impedance, or near 0.
You don't use any source with BA drivers, you should be sure output impedance isn't significant. Dymamic drivers doesn't matter.
