All NightHawks have the same tuning, and we have tight QC for driver matching and conformity with our golden curve.
Because NH has a low, flat impedance curve and very linear performance with regard to dynamics and output level, a wider range of amplification pairings is possible. However, I do highly recommend amps with output impedances of 3 ohms or less. In my experience, NH works best with clean, linear, "transparent" amps, and these tend to be solid-state. I have tested some amps that have higher distortion than NightHawk, especially in the midrange, which potentially means that the characteristics of the amp are more dominant than those of the headphone. For this reason, I tend to favor SS over tube with NH, but there are always exceptions. Ultimately, what sounds best to you is best.
An amp with a 50 ohm output impedance will be a poor match for NightHawk, and it sounds like that's what you experienced with the HDVA 600.
My personal favorite pairings at the moment are the Chord Hugo [$$$], Violectric HPA V100 [$$], and AudioQuest DragonFly [$]. But I just received a Moon Neo 430HA [$$$$] and Violectric V281 [$$$], and I expect these should both be stellar, albeit quite pricey.
