OkayKun
- Jul 4, 2015
I actually prefer the black over the red w the H6. It is a little warmer with a bit more bass in comparison. It's definitely enough to drive the H6 out of the iPhone and iPad. Android devices are another story as there aren't too many that support the DF.
Thanks for the input. That sounds good, I think I will try the black one then!
There's something I just didnt find out... can I still use the Control buttons on the cable? I know the Mic works and the Dragonfly is supposed to have analogue buttons, right? But is there a passthrough for the control buttons on the cable?
I don't like either one. I don't get why people buy these things. It's nothing more than an EQ that, in my opinion, doesn't sound very nice. I did like the black one more though. They both sounded muddy, but the black a bit less and has a more hifi sound.
Better buy a different amp/dac. Maybe your cans don't need much amp, but it can still add a lot with a bit more than an USB stick with some added power to add more than an EQ.
But it's of course personal like everything in audio.
I heard you say that before and thank you for your 2cents. Thanks for assuring the black one would be a better choice. Do you have a recommendation for an alternative?
I also need the Dragonfly to act as a lightning connection to my iPhone. It's small enough to use in the bus, I didnt want to use something much bigger and was hoping it could also improve audio a bit.
Cheers and thanks folks!
