dhruvmeena96
Yah, I know lolThese? http://www.zmfheadphones.com/pads-and-cables/zmf-suede-earpads
Any cheaper place to get them? The Shure 940 pads are less than $20.
And when you pick perforated Eikon from the drop down menu there, goes up to $70 ...
But it is for those people who were going for cowhide eikon pad (like zeos panthers)
Microseude pads does not lead to mid bass boost like angled pads are doing and perforated pads cleans up the bass hump. Second thing is that they somewhat tame the treble in good fashion. But the sound is coloured and very big staging without that cave-ish sound.
@jerg on his hifiman fuzzor mod said that we can do fuzzor mod on any driver... Felt on baffle and around driver opening.
So I am thinking of doing it on m40x
To avoid the edge deflection of sound coming through the small holes in the plastic covering the driver as well as reflection from our ears to dampen. This will clean up the treble.
As per @c61746961 , he covered two holes with tape but I will cover them with felt alongside the fuzzor mod.
Fuzzor mod kinda smoothens out the peak and cure some decay while also acting as impedance matcher for ears. So complete covering is kinda overkill that's why felt dampen.
@c61746961 also did cover one vent at the backside of driver with 3m breathable tape for bass hump reduction. I will be sticking a full tape with a small hole in it(compared to original vent, I am making it smaller by 1/2. From my hypothesis, bass hump should be cleaned but is not obstructed.
Now, one guy did dynamat and poly fill.
I think headphones dont need dynamat. Acoustipack foam or alternatives do the job better. I will be pasting the foam dampening everywhere he pasted dynamat. And instead of filling it with fiber fill, I will paste the back with acoustipack also.
And in last, sound professional velour pads red and periapt blood red cable.
This is am going to do for now.....
I will tell you when I get free time for this mod, but I think from my theory, that this will go pretty good and mod will also look clean
