pjyi
- Feb 19, 2013
It is earstudio es100.Cable ID and how did you attach the bluetooth receiver? Is that a Radsone or something else?
Here's a link to the instruction on how to remove the lock
I used the cable that was linked in that video. And I used magnets with adhesive sides to attach es100 on m40xYep, I have the lock removed on mine as well! Just was curious as to what cable you used and if you used something like velcro or 3M dual lock tape or what.
One on m40x and other in radsoneDo you just slap the Radsone onto the magnets or do the magnets also have to be attached to the Radsone as well?
Internal cotton/polyfill mod mentioned here
http://www.mediafire.com/view/y5i5wbnmn43xn15/ATH-M40X_modifications.pdf
Solderdude mod
Its a choice between stock + electronic or ear pads and damping foam changesCan someone explain the "electronic filter" in that document? What exactly is it?
you put that circuit between headphone jack and speaker unitI still am unclear exactly what the "electronic" or "electronic filter" is or how one gets/makes it. I am guessing someone builds it according to the plans shown on the document. Does anyone have a real life picture of the "electronic filter" they can post or point me to?
but i still dont get why you want to make one, when results are same and more comfort in physical mods like 2mm foam disk and shure 940 pads
electronic circuit will require you to feed more power
Aaahh that.I don't want to make one, I was just confused over what it actually was and wanted to see an actual version of it.
You did the agdr recommended mods to your O2?Schiit is not that great...
Its okay and the tuning is good.
I mean specs are so and so.
I prefer upgraded O2 with booster board or agdr cmoy
YupYou did the agdr recommended mods to your O2?
Did you change the potentiometer as well?
