pbeg7
- Oct 15, 2015
AD900x. The shp9500 is more analytical and slightly more fatiguing.
I really want to buy the AD900x as a present for a friend but have nowhere to listen to them first hand! I own the AKG K702, would anybody be able to compare the two pairs of cans for me? Or suggest anything better?
(The friend who I'm buying the present for listens to classical music and has no amp. His previous cans were Sennheiser HD570)
For classical music and no amp, there's not much better you can do in the price range.
Awesome! Thank you very much for your help! And is there anything you might recommend that's more expensive, as I don't mind spending more, or should I stick with these? (Bearing in mind no amp...unfortunately.)
The AD2000X is more detailed, with a tad more warmth, so the legend goes. Never tested it myself personally. It should be at or just under $500. I've heard the relationship between the 900X and 2000X is like the HD600 and HD650 respectively, but again, just what I've heard.
I don't know of many open cans that won't need an amp to sound their best at the $250+ range. To get the best sounds, they need a lot of resistance/power and with high resistance comes the need for an amp. I
Thank you! I've done some simple work on my Beyer Dt990's (detachable cable) but this one makes me nervous..
Could I ship my pair to you and pay you to do it for me??
Thanks again.
