I had the 1, the 7, and now the 7.1. The differences are very apparent, especially if you have a quality source.
As everyone knows, the DSP-1 module is on its 5th iteration. It's claims of making a source clock non-important are just not true. In fact, I am using a modified Transporter with two Audio-gd JZ1 clocks, dual torroidals, and an Audio-gd power supply (all with upgraded caps).
I determined this after trying multiple sources, and most recently because I discovered an interesting feature about the Transporter. When you are doing the initial setup you have the option for digital output of either "digital passthrough" or "word clock on digital output". When you select word clock on digital output the quality is far superior in every way. There are a lot of theories as to why this could be, from the people on the Squeezebox forums I've spoken to about it, but I won't get into that, since the passthrough feature was intended to just pass through whatever word clock signal was coming from whatever input is being fed into one of the Transporter's input jacks. What is important is that the word clock on digital output is including the generated word clock data from the Transporter which in my case is being generated by the Audio-gd JZ1 clocks. In my Transporter, everything is disabled except the digital output: the internal DAC is disabled, the original clocks have been removed, the original transformers have been removed, and the analog outputs have been disabled.
To make a long story short, the DSP-1 can perform very well, but only if fed with an accurate/stable word clock (and word clock refers to the signal, not to be confused with a master clock which generates the word clock, and can be either an internal clock circuit or an external device). Don't expect to get world class performance out of your Ref 7.1 (or any other Ref model) if you are feeding it a word clock generated by a poor quality oscillator. What do I consider a poor quality clock? An oscillator with greater than 2ppm stability (you want it to be less than 2ppm... the JZ1 are about 1.5ppm... the uber expensive Antelope Audio Rubidium oscillator is rated at 0.05 parts per BILLION), and a clock with high jitter. Ideally you want a TCXO (a thermally controlled oscillator), which regulates the temperature inside a miniature oven. Oscillators are very sensitive to temperature fluctuation, and this is also one reason why a digital source sounds better after it has had time to warm up. You also want multiple fixed frequency oscillators as opposed to a single, variable frequency one.
I'm sure some will disagree with me, but digital designers won't: a clock circuit is far more important to the end result than the type of DAC chips used (assuming the DAC chips are of level playing field and are capable of accepting the same bit rate and sample rate.)
