I just had a close look at the RE5's ACSS wiring and indeed it's only using pins 2 and 3 (pin 1 and 4 are jumper-ed together in my RE1/Phoenix for GND lead) I guess Kingwa decided that the GND line was unnecessary with the RE5. Not to worry though it's still balanced operation since pin 2 is + and pin 3 - IIRC.
* In the DAC19 the pins used are the GND and + (1 and 2) which is single ended. The C2 ACSS input will be single ended (using pin 1 and 2) obviously.
* I think however the single ended wiring scheme might be inverted using pins 1 and 3. I seem to remember from rewiring the single ended and acss/xlr I/O of the RE1 and the Phoenix I had to invert some connections to gain correct phase response. After looking at the C2 and DAC19 ACSS connection pics it looks as though they are inverted (pins 1 and 3). I hope I have those right. I'm sure Kingwa will chime in If I've made an error.
I know this sounds like I'm confused somewhat (maybe a little...
)..at any rate maybe this post has helped a smidgen.
Peete.
