The picture is misleading. It only shows the top module that needs updating. You can use the pictured cable to connect to the top module without any obstructions. It is the module below that has a problem. The upright capacitors to the left of the pins make it impossible to connect to the lower module with pictured cable. What Kingwa is suggesting I think is using individual DuPont female to female wires to connect each of the 5x2 pins on the lower module to the corresponding pins on the blaster. I think a tweezer will be needed. The recommended blaster kit on EBay has the cable pictured but not the individual wires I think are needed for the lower module (about US $3 on EBay).http://www.audio-gd.com/R2Rupdate2.htm
According to the procedure (first picture), space is tight indeed. I would just chop off platic from the right side if the flat cable. If nothing else in the way besides this capacitor on the right, that should do it.
Audio-gd R2R DAC Thread
FredA
- Dec 15, 2013
Don't srew up with pin matching then!The picture is misleading. It only shows the top module that needs updating. You can use the pictured cable to connect to the top module without any obstructions. It is the module below that has a problem. The upright capacitors to the left of the pins make it impossible to connect to the lower module with pictured cable. What Kingwa is suggesting I think is using individual DuPont female to female wires to connect each of the 5x2 pins on the lower module to the corresponding pins on the blaster. I think a tweezer will be needed. The recommended blaster kit on EBay has the cable pictured but not the individual wires I think are needed for the lower module (about US $3 on EBay).
Isn't it possible to unscrew the da-8 modules?
FredA
- Dec 15, 2013
If so, i would just unsecure the bottom da-8 board and put some foam underneath to lift it up. Don't know if Kingwa would approve this procedure however.
africanus
- Oct 26, 2014
1. DSD noise issue. This has now been confirmed by several members, and is therefore, for me, a known fault with the R2R-11. It has nothing to do with the fact that it’s a NOS dac, because plenty other NOS dacs don’t have this issue.
It seems to be a problem only with R2R-11. My R2R-1 is dead silent. No noises whatsoever in both OS and NOS modes. Tested with Stax SR-007 and Hifiman HE-6. My configuration:
PC (DSF files) -> Foobar (Output mode: DSD only; Output: DSD: WASAPI (both push and event); no processing) -> R2R-1 (oversampling and non-oversampling modes)
That’s very good to know indeed!It seems to be a problem only with R2R-11. My R2R-1 is dead silent. No noises whatsoever in both OS and NOS modes. Tested with Stax SR-007 and Hifiman HE-6. My configuration:
Elder
gLer, thanks for your reply.Sorry to hear about your issues, but at least you’ve come to the right place. Let me summarize the current situation for you so you’re caught up:
1. DSD noise issue. This has now been confirmed by several members, and is therefore, for me, a known fault with the R2R-11. It has nothing to do with the fact that it’s a NOS dac, because plenty other NOS dacs don’t have this issue. It’s simply a hardware fault that wasn’t picked up in testing, and is unlikely to be resolved by AGD because they refuse to acknowledge the issue. Like you I love the sound of the R2R-11, and as a ladder dac I’m aware it is optimized for PCM playback. In fact I’ve been testing DSD converted to high-res (24-176) PCM with the R2R, and indeed the PCM files sound better to me than native DSD.
This leaves me with two options: convert all my DSD files to PCM and enjoy them in high quality with the R2R-11, or sell the R2R-11 and buy a proper DSD-capable dac. I haven’t decided which option I’ll take, but I’m in no rush to sell because frankly it’s the best sounding all-in-one under $1000. When I’m ready to upgrade my sources, I’ll reconsider it then.
2. Pops between sample rate changes. This has allegedly been resolved with a firmware update (that’s actually quite difficult to apply). I’ll be getting my R2R-11 updated by my local supplier shortly, and will report back then.
3. DSD lower volume than PCM. I’m afraid that’s not an R2R-11 fault, but actually a ‘feature’ of most DSD playback software. DSDs are generally recorded with -6dB level to avoid clipping, and this is what you’re hearing. When you convert DSD to PCM you have the choice of restoring the 6dB of ‘lost’ volume, and therefore your PCM files should sound significantly louder at the same volume level on your amp.
HTH.
I like the overall sound of R2R, but I like it even better with DSD. The only complaint I have is the background noise with some recordings.
Concerning the DSD level, it drops down more, relatively to PCM, then the other DACs I have with Sabre chip. It is OK if my playlist have DSD only, but for mixed PCM/DSD playlists it is annoying.
I use JRiver media center that can convert to PCM on the fly, so there is no need to convert the files. This could resolve the level issue for mixed playlists.
I suggest you to try JRiver before converting your DSD library. I believe Korg Audiogate is capable to convert DSD to PCM in real time. Other player can do it, as well. Like foobar2000.
Actually, it is easier to get a player that converts DSD to PCM than getting one that streams DSD to the DAC.
I am trying to get the USB Blaster to update my unit firmware and hopefully, the pop issue will go away.
Thanks.
Elder
Just placed an order for R2R-1 to be used with my NFB-1AMP. Now I'm not sure whether to get XLR cable or AGD's ACSS cable. Which one works best?
Elder
This photo shows the problem.The picture is misleading. It only shows the top module that needs updating. You can use the pictured cable to connect to the top module without any obstructions. It is the module below that has a problem. The upright capacitors to the left of the pins make it impossible to connect to the lower module with pictured cable. What Kingwa is suggesting I think is using individual DuPont female to female wires to connect each of the 5x2 pins on the lower module to the corresponding pins on the blaster. I think a tweezer will be needed. The recommended blaster kit on EBay has the cable pictured but not the individual wires I think are needed for the lower module (about US $3 on EBay).
FredA
- Dec 15, 2013
Get an acss cable from Magna hifi or Double Helix. A high-quality xlr cable, will work very well also, better than the audio-gd acss cable.Just placed an order for R2R-1 to be used with my NFB-1AMP. Now I'm not sure whether to get XLR cable or AGD's ACSS cable. Which one works best?
I am not making much progress regarding updating the R2R 11 firmware. The last response to my emails was to send a picture of the blaster with the various cables unattached laying next to it and the same picture they have in the instructions with the ribbon cable attached to the top module. This was the written response:
"The blaster include the wires already mark the defined name, and we also mark the pins defined.
If you have not that wires, can you push the block cap and push into the default wires?"
Anyone know what this means?
FredA
- Dec 15, 2013
It means that one of the wires supplied with the blaster should allow acces to the pins, which are identified on the pcb, i assume. If no cable can do the job, he suggests to genlty push away the capacitor blocking the way.I am not making much progress regarding updating the R2R 11 firmware. The last response to my emails was to send a picture of the blaster with the various cables unattached laying next to it and the same picture they have in the instructions with the ribbon cable attached to the top module. This was the written response:
Pharmaboy
This is very unscientific, subjective reply--but here goes.
When I got my NOS 19, I agonized about whether to convert the ACSS output vs RCA. This would be far more convenient than ACSS, which would require an amp/preamp (downstream of this DAC) w/ACSS input--which I didn't have then and still don't have. Regardless, I went in search of every user comment & review I could find mentioning ACSS. This mean the epic Head-Fi DAC-19 thread (there is no thread for the NOS 19, which apparently never sold very well)...plus other headphone audio site. What I found was this:
- Most mentions of ACCS output to an amp/preamp didn't give any detail on sonics
- A sub-set of mentions of the ACCS output went off the deep end into electronics theory, optimization of current flow vs voltage flow through the ACCS connector, etc. Not having my electrical engineer degree, I bailed on the most technical of these comments
- Very occasionally, someone weighed in, saying he or she had compared ACCS to RCA output and preferred one over the other. Of those who preferred ACCS, I read things like:
- Clearer than RCA
- More detailed than RCA
- More "accurate" than RCA
- Somewhat brighter than RCA
Maybe this is just my ignorance speaking, but I've been pretty happy without ACCS...
i have AGD NFB-1AMP and denafrips ARES both balanced and i similarly agonized over ACSS and i really wantd to get R2R1 just so i can see what ACSS is about. i think if you have two AGD equipment u owe it to yourself to try the ACSS. i might still do that just for the curiosity because denafrips is already a hell of a DAC and i love it. i do miss my R2R11 tho.
- Jul 30, 2015
I tend to regard ACSS like a proprietary connection type, even if technically it's open source. Nobody that I'm aware of uses it besides Audio-gd. So, if I was planning on investing in more Audio-gd gear downstream, I'd consider investing in it, but truth be told, I'm good with my pre/amp/receiver situation right now. I'm more into the idea of getting an R2R 2 for my living room, but that's way off in the future, once I move into a bigger place with better acoustics.
lentoviolento
- Feb 17, 2017
I was about ordering nfb1 yesterday. I don't know if get nfb1 or cayin iha6. In the future i would like to add ares to the chain. At the moment i have r2r 11... Why you say you miss r2r 11? Do you mean as a dac? How does it compare to ares? Or also as an amp? I am using gilmore lite mk2 atm and i find much warmer thant audio gd.
