Hello Guys,
Has anyone tried any USB converter with the R2R-2 DAC?
I mean a device to convert the USB signal from a computer into a I2S (HDMI) or SPDIF (Coaxial) signal. A device like L.K.S. USB-100, Gustard U-12, Schiit Eitr, Singer SU-1, Mutec, etc.
If someone did it, wich one did you try? what were the changes on sound quality? was it worthwhile?
The answer to your question is almost (but not quite) a completely different topic for a different thread. There are so many converters out there. At any given time, some are older/in disfavor; and others are the "flavor of the month."
The other issue is that not all inputs sound equally good on many DACs that allow USB in vs coax in vs optical, HDMI, whatever. So the DAC's input circuitry & its quality become variables, as well as the converters. As if that weren't enough, there are also different cables used for each input. Many variables, many combinations.
I have 2 multibit DACs now: Audio GD DAC-19 & NOS-19...NOS is my day-to-day DAC . I used 2 other delta-sigma DACs in the past. For the last 10 years I've used Musical Fidelity converters (now up to the discontinued 24/192 model). Started out w/optical cable (which sounded better than USB straight in on the 2 delta-sigma DACs); eventually moved to coax, which sounded better on 1 d-s DAC, and still sounds better on both AGD multibits.
I started out w/an inexpensive Billy Jeans cable, which I was happy with. Then ~3 years ago upgraded to a (for me) pricey silver coax cable, the Oyaide R-510. Man, that was IT. Sound got even better.
Sure, I'm restricted to 96 kHz hi rez when using coax instead of USB straight in. Doesn't matter to me...have just 2-3 high-rez files.
All this may change, of course, if I find that USB sounds better on my next DAC, which almost certainly will be the R2R 1. Then again, even if USB in sounds better, there are USB-to-USB re-timers/decrapify'ers out there that are praised for for improving sound. So my search for the sonic holy grail will never end...
