I'm not sure if I have a bad pair of he-560's but they have always been super quiet in my opinion. They seem to be rediculously power hungry. Albeit when they are maxed it sounds like a concert level. on 15 it sounds like someone is whispering. From 0-10 it's almost no volume. Am I missing something? I know my hearing is perfectly fine. I've been tested and am not deaf or deaf tone etc etc. something is weird if you are at 15. Once I get a balanced cable I will reply again. SE is less than one third of the power. So maybe 45 would be about where you listen? That sounds reasonable. It's hard to believe only 6db for three times the power.
The specs are
9500mW / 25 ohm
8000MW / 40 ohm
3500MW / 100 ohm
1200MW / 300 ohm
600MW / 600 ohm
And SE
3600mW / 25 ohm
2500mW / 40 ohm
1100mW / 100 ohm
400mW / 300 ohm
200mW / 600 ohm
The specs are
9500mW / 25 ohm
8000MW / 40 ohm
3500MW / 100 ohm
1200MW / 300 ohm
600MW / 600 ohm
And SE
3600mW / 25 ohm
2500mW / 40 ohm
1100mW / 100 ohm
400mW / 300 ohm
200mW / 600 ohm
