Liu Junyuan
- May 22, 2014
Actually, I feel like the amp holds up quite well. Even just using the SE output, there was a notable improvement in soundstage and overall presence from my old amp (NFB-15.32 built-in amp), which I found to be pretty on par with my old Matrix M-Stage. I also noted similar results when comparing the amp stage to the Geek Out SE (which uses the GO 1000's amp), though obviously there's an even bigger difference in output there.
Obviously, going to the balanced output gives even more gains.
Those are some nice amps you listed. What DAC would you use them with, if you don't get the A-GD? I was also considering the Gustard at one point. If I hadn't been set on going balanced with my next DAC and Amp, I probably would have gotten that one. Of course, knowing what I know now, I might just get the NFB-29. It's really hard to beat the value of the A-GD options. I just don't see any other combination of DAC's and Amps that are on par for the price.
I haven't heard enough high end DAC's and Amps to back up this next statement, but I do have a theory: like with all the headphones I've tried in the $200ish range, I think that if you've done all the research and now you're agonizing over small differences, you should just pick one and get it. I'm sure you'll be pleased with any of the ones you get, especially if you're not A/B'ing directly with the other choices. (And if you are A/B'ing, it shouldn't be a difficult choice anyways.)
Thanks for the information. I would use the DAC on the A-GD, but I would also roll between it and my Gungnir, to change things up when I wanted. The advantage of going with the A-GD is that I would have more options as well as a nice SS amp.
