haloxt
- Sep 26, 2008
You could put some silicone pad on the desk, and the nfb-12 on top of it. Or sticky tack or for less mess silicone putty.
What cause the roll off at NFB12.
The WM8741 setting is no fault at NFB12.
This setting is for accept 192KHz input.
The NFB12 can had better specs on page.The two caps in the red loops cause the roll off.
The NFB11 is same with the NFB12 except the digital parts and TWO caps.
In NFB11 we applied 100PF, but in NFB12 we applied 470PF.
An electronical university man can easy design a excellent specs gear. But the sound maybe not excellent.
We also can build a excellent specs gear, but we want more listen not only meter test.
In NFB11 we plan to design its sound very revealing, so we choice 100PF caps for it.
The NFB12 is finished design with NFB11 at same time, we want to design its sound a bit smooth , and forgive so we spend more days than NFB11 just for adjust parameter and listen, final choice the 470P.
For people who want better specs, you just simply replace these two caps by 100PF (or lower).
Sorry my poor English, I want to study English again, but I like listen musices and design PCB more than study English.
Hi madwolf,
also interesting, but I guess a bit, if your setup is correct. All results are worther than the other ones before: All graphs are not even touching 20 kHz down to the -4.5 dB, none of them
Hi Holland,
very interesting. I am not sure wether we are talking about the same filter, you mean the filter before ADC, right? If I've got Kingwa right, he was talking about the lowpass after DAC. But anyway, you are imo on the right track. As mentioned few times the filter after DAC would influence each signal the same.
But your approach would mean to redesign?
Defective product = refund. Kingwa, I send you a message to ask how to proceed.
PS: I hear till 19kHz and it's not everybody's case, impressions on what I consider a defect may vary.
I don't gree it is a defective product.
At first we design the NFB12 we want to make it different flavor to the NFB11 and I want to make it with smooth sound , and we have mark on our web it is a bit smooth and forgive for source .
It is work on hardware mode, so it is setting is follow the performance request and this is the best setting at 192KHz accept ability .
The table of #577 post, it is so the max oversample setting. The NFB12 want to accept 192KHz oversample so the Pin22 must setting at 1 . Otherwise the NFB12 only can up to 48KHz or 96KHz.
Does anyone had better setting in hardware mode?
LiqTenExp post at #578 just customize setting, in face the USB can accept 96KHz and coaxial/optical can accept 192KHz but he limit USB at 44K and coaxial at 96KHz.
About the high frequency roll off not mean it is a defective product, just read the diagram of #556 I was post, the Simaudio Moon Evolution Andromeda Reference CD player which is a colstly more than USD20K gear, also so the high frequency roll off around -3DB ,does anyone think it is a defective products?
The high frequency roll off define sound flavor, it bring a smooth flavor.
But the roll off not mean its sound unneutral, the neutral is depend on the circuits components less coloration, like some tube gears even without roll off at 20KHz but sound tube like (coloration).
For supercurio: If you define the NFB12 is a defective product, please offer the effective evidence.
For LiqTenExp post at #580, addition a MCU can check the oversample rate and setting the Pin22.
But I think a MCU join in not a good idea for this price rang gear. In this price rang gear , the power supply is limit and the size is quite small, the MCU maybe bring more disturb to the sound make the sound quality degrade .
