I ever wrote a article and post at a Chinese audio magazine in 2010.I can't fully interpret the article to English base my English ability.
I think the 192KHz support not a real upgraded.
The software (the recorders ), there is a real improved than 44KHz.
But the hardware, a lot newest D/A chips only support up to 96KHz or lower. The newest DA chips declare support up to 192KHz not real open a new field than the older PCM1704.
The WM8741, the ES9018, at 192KHz input, they want to work on the "high rate" filter mode.(Had declare in their PDF files.)
Read from the output waves of the WM8741 on oscillograph , I presumed the 192KHz input is working at 2X times oversample. At 96KHz is 4X (8X of some other chips ) oversampling.
If the digital filter setting to 2X oversampling, the PCM1704 can working at 384KHz ( PCM1704 can support highest 768KHz input ).
In theory the 8X oversampling sound more detail and black backgroup than 4X and 2X modes , and I gree the throry with my experience.
So 192KHz files sound maybe no benefit than 96KHz files after the DAC.
But I gree the WM8741 is a excellent DA chips, its sound mellow and analog taste, the soundstage is quite wide and deep than some other chips. So we design the WM8741 based DACs was follow its flavors.
Personal I like it's working at 96KHz or lower modes, but people always like the 192K support on paper.
Sorry again for my English.
PS: Edwin is not me, his English is much better.
For people who think that NFB12 sound bad, I believe you are feeding the NFB12 using a 44/48khz input.
I strongly urge you to feed the NFB12 with a 192khz source and hear the difference.
Using a 96k source is only slightly better as it is just half way there.
I know 192khz source is hard to find but try.
After reverting to Pin 22 to 3.5V. the sound become darker and veil, The tonal balance is off at the high end. After some listening I know that this cannot be right.
Again I remove Pin 22 from the PCB and after I confirm with a few song the sound is great. At least the high end gives the correct tone.
AB test with another system to confirm.
The same amount of hissing is heard at both setting.
Taken from Page 40 of Wolfson 8741 datasheet
We need to set the correct setting for this pin to the source sampling frequency if not the digital filter will be off.
The NFB12 current fix this pin at one fixed setting.
From supercurio graph the NFB12 is correctly configured if the input source is 192khz
There a very slight error if the input source is 96khz
But if the source is at 44khz the high frequency is rolled off prematurely.
It cannot be the 470pf or 100pf as pointed out by KingWa. because if it is this it will affect all the graph at different source frequency.
高音的问题只有在用户使用44/48khz输入时才会出现。
如果输入是192khz高音是没有问题的。
96khz输入时影响不大。
你说的那个470pf capacitor,看来影响不会那么大。有影响的话,影响44/96/192的程度也会是相同的。
可是我从supercurio的报告看到影响的程度是不一样的。
Wolfson8741的说明书第40叶,写到不同的输入是要用不同的设置的。 可是我量到这是锁定在3.5V的。
