That really blows. It your first link, is that with or without the HD650. It looks like it is without, but I want to confirm. The HF rolloff is unacceptable. -4.2dB @ 20KHz, starting at 2KHz. Hopefully it's not a design issue, and someone just stuffed the board incorrectly (not likely, but hopeful).
Someone should ask AGD about this.
Also, if someone can reverse engineer the DAC configuration, that would be great. What filter modes are the WM8741s put into? Is de-emphasis enabled or disabled?
Most of what we hear as treble is in the 5k to 12k range. There's almost nothing to hear at 20k. MP3 compression usually filters out everything above 16k for example.
Audio-gd's other DACs have similar rolloffs in measurement, see this thread:
http://www.head-fi.org/forum/thread/435290/rmaa-test-results-for-audio-gd-dac-19mk3-and-reference-1
It's likely a digital filter.
Very likely, set to slow roll-off, same as in most high-end DACs.
I would indeed ask Kingwa about the measurements, but remember that it's a $200 combined unit, not a $2000 one. However, that stereo crosstalk measurement corresponds with my experiences of the low-end Audio-gd gear that with HD-600s one doesn't get a very wide soundstage. You need to go up a tier for that.
