kennyk64
- Apr 23, 2014
easy way to cheeck if it is software / firmware related is to try and hook up using Spdif.......................That said I would bet it is Software / Firmware related, I got fed up with the substandard software / firmware and bought a usb / spdif converter which solved the issue...............However it truely sucks to have a component that is supplied with usb that is frankly the worst implamintation I have seen on any product to date
The sound of the DAC is good, and build quality seems good as well.....................They just need help with the software, and support
I will try with spdif later on. I have emailed them, and regarding the YouTube video they can't answer because they can't access YouTube in China.I really do agree they really need to improve with their software.
If Foobar2000 stops playing an audio files, I would assume it's more of a Foobar2000/windows issue and not the NFB-11.
I bought my NFB-15.32 back in early Nov. and tried the firmware upgrade not long after, but I only got the USB working a few days ago.
I've never had any problems before with foobar before. I switch back to my older DAC and there is no prob. Even playing at default settings gives the same result. It happens to browser video, all players and also games, so I suspect its software error. Or it could be my playback device settings?
