Douglaster
- Nov 23, 2012
Did you get it with the TCXO upgrade which cost a bit more, if not it can be installed later on your self. When I had the 15.32 and for me it made it more smooth and transparent, but for the 11.32 it should do the same if not slightly different. I did that but it is for the USB input, if your gonna use optical or coaxial then there no point for the TCXO upgrade. Also it might come with the latest firmware installed, if so then use the newest drivers for the USB input.
No, normal TXCO ones.
It is the newest latest version of it. And ill use only USB.
When it arrives ill do a review for sure ( i didnt find anyone with my case (from receiver to NFB-11).
