Hello,
Which one is better suited for the Denon D7200 and D7000 ?
On computer end of USB cable. Search this thread for "5V pin". You need to put slim small piece of electrical tape onto the rightmost pin of USB 2 male connector as shown here. The idea behind it is to block power from entering the cable, as R2R11 uses its own power supply.
Many DACs will not work from data line only. So you have to try to know.By the way.. it's a good practice to block the 5V pin on any usb cable with any dac.. tested on the Topping D30 as well as the R2R11, seems like all of the dacs can get a clean signal with a complete black background while blocking the 5v pin? why do we even need the 5v?
+1You are absolutely right!
I would recommend this to everyone who has a separate dedicated power supply (and does not use power from USB)
Hi guys! How do you connect the device as a DAC to a separate amplifier - what do you choose: 1 Vrms or 2.5 Vrms ?
(as you now, the R2R-11 has two fixed levels of a linear signal (2.5 Vrms fixed output, hi-gain), and 1 Vrms (fixed output, low-gain).
Which signal is better to apply from the external DAC to the amplifier: 1 Vrms or 2.5 Vrms?
Whichever sounds best. Some amps will saturate when fed a 2.5v signal. Otherwise 2.5v should be better but there is nothing like triying it.More opinions of others on this?
